Brake Master
New Jersey
Have a 76 40 with front disk and rear drums.
Losing fluid in rear res.
Looks like it is leaking from between the master and the booster.
From the research I have found, I believe that the brake master needs to be replaced . If that is so and I plan on converting to Gm style rear disks in the future, Should I still go with straight replacement or is there a better option?
Unless I got all wrong in the first place?
Install a new stock OEM master, remove the residual pressure vavle in the rear circut, install your disc brake conversion, and drive on.
Good luck!
-Steve
