Brake line routing question.
Southern Oregon
I have a '69 fj40 that I am starting a 4wheel disc conversion. The way it is now the brake line runs forward on the framerail to each front wheel, then back to the rear axle. My question is rather than build all new lines, would there be a problem capping the junction block after the right front wheel, and running a new line across the firewall and down to the original rear line? There is another junction just behind the firewall going to the rear. I will of couse be replacing the original single resevoir master cylinder, and would flush the lines to see how much crud comes out of them, but I see no signs of external deterioration.
In theory, no. As long as you can accomplish this without a leak.
Not the way that I would, or have done it, but to each their own.
Good luck!
-Steve
I'd probably put in a new T for the front rather than rely on capping or plugging any outlet. Just one less potential leak.
I'm assuming from your "running a new line across the firewall and down to the original rear line" that you're equipped for and skilled at making double flare tubing ends?
