Brake line questions
Sheridan, Wyoming
Hi all,
I am just connecting up the brake lines on my disc swap, the problem I have run into is I bought stainless lines (SOR) from the 'T' on the back of the disc brake backing plate to the tab welded to the axle. The problem is the short hard line from the tab to the 'T' on the axle. There seems to be two different flares involved here, are my solutions to have one made or what line are people using when doing this switch.
The vehicle is a 72 fj40 and the donor disc parts were froma 84 fj60.
Thanks.
Brian
What part number brake lines did you purchase from SOR?
You will need FJ60 hoses if you have FJ60 backing plates...
:beer:
Poser,
My worries were based upon looking at the old line and the flares on it. Upon closer inspection of the 'T' on the axle and the end of the new stainless hose it appears they are in fact both the same flare and the problem was that the PO had the wrong line on it, I am not sure why it did not leak all the time. At any rate I will assemble with the parts in hand and am fairly sure they should not leak. (I did order lines for a fj60) Thanks again very much.
Brian
Poser,
Oh yeah one final question if you don't mind, I bought a brake master/booster combo from a member here off of an fj62. It is considerably smaller than the huge thing I presently have on my truck, to gain more space around the carb would switching to this booster work? Thanks.
Brian
Should not be a problem.
Just verify when installing the booster and master assembly, that there is proper pedal free-play, and that the master cylinder actuation rod that links the booster to the master cylinder is not pressing in on the master cylinder when you bolt it up, otherwise your brakes could end up dragging.
Just take your time and test-fit things and you should be good to go.
:beer:
