brake line location
Year model might help. They all run over the cowl down the right frame rail just in front of the firewall. Rear runs along the inside the frame. Rubber hose the the axle then steel line to each side. Front originally ran across the front frame member and hose down to each backing plate. Later a hose to the axle then steel line to each side. That is a simple explanation. Duel circuit verses single circuit. Drum verse disc on the front. Those were not all the same.
