Brake Lights on Steady...
Whidbey Island, Wa
Just noticed that my rear brake lights are staying on steady. Both tails and the horizontal one on the lift gate.
Anybody had this issue, or any ideas on what to look for?
Thanks,
Dave
Brake switch out of adjustment/stuck or a short somewhere, I'd lean towards a brake switch problem.
Our LX brake lights stay on when it is really cold, I think it is the pedal switch (that I haven't changed out yet:doh:).
You may have a similar problem, in that the switch doesn't disengage, so the light stays on. Just My .02.
BTW our local parts store said they have the pedal switch, so it must be a common item.
It's on a bracket above the brake pedal, if you stick your head under there and operate the brake pedal you should see a switch with a plunger on it, that when you release the brake pedal the plunger is pushed into the switch and when you depress the pedal it comes out(thats the way most of them work anyways)
You can test is by unplugging the switch and if the lights go out, thats your problem.
If the brake pedal is not pushing the plunger back in all the way, then it is out of adjustment.
