Brake Light help
Texas
Hello all. I am new to this site and a relatively new owner of a 72 FJ40. I am having a problem with my passenger side brake light and am now thoroughly frustrated. I am not very knowledgeable when it comes to working on autos but am willing to learn and have already successfully worked my way through a few issues I have had.
My brake light on the passenger side recently stopped working. The running lights still work and not having any other light problems on the vehicle. Replacing the entire taillight and braket was something I had already planned to do as there was a lot of corrosion happening so I did. I didn't expect it to fix the problem after replacing and I was right. Again, I have power back there and the running light works fine.
Wanted to see if anyone has had this problem and could help point me in a direction because I don't really know where to look. Can the brake light switch be the problem if one of them is working? I haven't taken that out to look at it yet but can.
Any ideas or direction would be much appreciated.
Not the brake light switch, but could be the turn signal switch. Does the light flash with the passenger side turn signal?
Thank you for that. I am honestly not sure if the turn signal works or not. I am pretty certain that the front blinkers work on both sides....would they all be out. About to take a lunch break and run home and check. Thanks again!
For your year (like my 69), everything seems to center around the turn signal cluster. My PO had made a mess of my wiring; it was all there but he had hacked in a trailer attachment. When I got my rig, I had no working lights. After spending a month off and on, I got all lights fully functioning. I highly recommend Collerman's electrical schematics. The FSM has info as well. Lots of electrical problems for early 40s is usually caused by bad grounds. I replaced the fuse block--cheap to do and a at least you eliminate problems there. My guess is that you have one or more bad connections at the turn signal cluster. Also check the connections at the rear lights; if you jiggle them around with someone else operating the system, you may be able to discover the bad connection. m
Have u simply tried replacing the bulb yet ?
filaments can look good , but be bad , bulbs can be damaged in shipping even on a new OEM light
turn signal = blinker
Ha, yes I know blinker=turn signal. I just happened to use both in the same post...sorry. Thanks Martyt for the suggestions. I didn't get to check it at lunch like I wanted but will tonight. Bulbs are good as the running lights work fine. I found out the hard way about grounds with that thing because when I initially hooked up the new light I hadn't actually mounted it yet. After reading on other posts went ahead and mounted it and the running lights came on. Again, I know I am a rookie at this but want to learn. Y'all have been a big help already and will let you know the outcome once I get to mess with it.
To make sure what I'm showing here matches your year, you'll need to determine if you have one flasher for both the hazard and the turn signal. From what Coolerman posted about the manual @Solace in Solitude linked above it fits your year, unless you possibly have a late '71 that's titled as '72? It helps me to follow the path to visualize where the problem might be. It also helps save a lot of time to figure out where to start looking for the weak link with jumpers.v
Download the full size .tif instead of the .jpg from his website for better clarity. This is just an overlay I threw together. The arrows indicate the flow of electricity. Hope it helps.
Again, thank you all for your help. I am really confused now though. After your advice to check the turn signal I went home and first thing checked to make sure the passenger brake light still was not working....it wasn't. I then tried the turn signal which did work. I then tried the brake light again and it worked. I know. It is almost as if the turn signal activated the brake light because I have been able to recreate it multiple times. So, I know there is power and the light is not the problem....it is just figuring out why it seems like I have to turn signal before I want the brake light to work. It will work for awhile and then I will have to use the turn signal to get it to come back on. Crazy I know but there has to be something loose or something...just don't understand in what scenario activating the turn signal would allow the brake light to start working.....until it stops, then do it again. Haven't been able to spend much time other than that looking into it.
Owning a 40 can be a lifetime of chasing electrical gremlins. I had similar issues. I ended up doing a lot of trial and error regarding wire connections and using a couple of jumper wires for some connections. The brake lights were the last things I got right. Have patience and don't be afraid to think outside of the proverbial box--all is knowable and solvable.
It sounds like you've almost solved it! On a '72 the same wire is used for both the both brake and turn signal path, and the everything runs through the turn signal. So if your turn signal works right 100% of the time you can rule out everything from the turn signal back the light. The turn signal switch works by lifting a couple of pieces of bent copper in and out of contact, opening or closing the electrical paths. In the neutral position you probably have just enough corrosion on the RR (right rear) contact and when you slide it back and forth a few times making a signal it gets just enough juice flowing through to overcome the resistance for a bit.
I assume you have the later '72 and not the early with the externally mounted switch. Disconnect the battery. Pull the steering wheel, unscrew the plastic housing, flip it over and spray the turn signal contacts with a little DeoxIT. I bet you'll be back in business. You may want to spray the plug contacts where it plugs into the main wiring harness while you're at it too. :beer:
