Brake Job Post Mortem
Colorado
With the truck pulling during braking and doing some tinkering with the front calipers, it was clear that I had a stuck piston or two causing the issue. The question then became weather or nor to rebuild the calipers (97k miles on the odo) or go for a rebuilt unit from Toyo. After much reading on Mud, I decided that my limited auto skills might be able to tackle rebuilding the front/rear calipers. Futhermore, I figured if I was going to rebuild the front, I may as well do the whole truck. :eek:
Cdan the Man set me up with all that I needed for the rebuild and over the weekend went about tackling the task. I read quite a few posts that stressed the frustration of pulling the pistons from the caliper and as many, attempting to apply the new seals. Fortunately, I was able to get the pistons out without too much trouble and found the job to re-install the new seals/pistons pretty easy.
I also replaced all rotors (fronts were ridged and one rear rotor was chewed up pretty bad from metal on metal contact) and went with 100 series pads up front. What I didn’t expect was that while the truck pulled to the left and the front right calipers were in fact stuck, so were the left, at least a few of them.
Like others have noted, Toyo does not provide enough piston lube. I found that applying lube to the installed inner seal, shaped like a ring, made it much easier to re-install the piston - if you should have only applied lube to the piston (as I did at first). In fact, I came to this realization from ripping up one prior to applying lube directly to the ring.
In summary I thought the job pretty easy to do, even for me, a 1/2 :banana:mechanic. :flipoff2:
