brake issues
Long Island, NY
I purchased a complete rear axle that had 500 miles on it.
It has a detoit in it along with irocZ disk brakes.
Here is the problem.
You know that "T" that bolts to the housing?
1. The GM lines that come from the calipers to that T are larger diameter lines than toyota.
2. That "T" is a modified stock toyota one. It has larger fittings going into it. Which work fine.
3. The issue came when I installed the toyota flex line down to the front of that T.
4. It will screw in, but is loose. Almost like 1mm to small. I am assuming it is SAE along with all the other fittings on the housing.
Q1: Is there an adapter I can get to still use the Toyota line?
Q2: I realize that I need to get like a 7-10" over stock brake line anyway, should I just have it custom made to have one end SAE and the other end metric - to fit into the cruiser hard line at the frame?
Thanks,
Ragman
I would get something that is SAE and then have a hard line that is metric on one end and standard on the other; over having a custom hose made...unless you want to purchase a couple. Double flaring brake lines is not that big of a deal, and when done properly, really clean things up, over having multiple adapters in line...
I have had sticks snag brake lines in the past and ruin them....
Napa/Carquest have illistrated buyers guides in the back of the books that have brake hoses...you should be able to look through that, and find something that will work for you.
At one time, I had a rear brake hose from a mid-80's 3/4 dodge van going to my rear axle....
You should not have a problem finding something that will work for you.
Good luck!
-Steve
