I have been through the mandatory inspection 4 times now because my rear brakes are more than 35% different in stopping pressure. The issue is with the right rear drum, I have changed both pumps, pads, bled the system, cleaned the lines from the T on the diff (I have good flow and pressure at the T and when bleeding) and adjusted to the point where the shoes are dragging without any pedal. With the drum off everything is working fine when pushing the pedal but at a 5-10mph roll I can lock up all the tires except the right rear. I am lost.
