brake hose size.
My local parts store has brake hoses in whatever size I need as long as I can tell them what fitting, size, thread pitch, diameter they are. A much less expensive alternative to the braided steel lines. Can anyone help me out? How long should I get for OME J springs with OME L shocks? Thanks a bunch!
Thats cool. I'll try that then. Cheaper and easier than rubber lines. Does it work in the front too? Is there enough "slack" for an extension up there?
It did for me, moved them forward and down, using the same method.
Gday,
On both of mine with "Ls", I just bent the top mount a little, and have spaced the bottom off the diff housing about 5/8", with a nut. - Front and rear.
Unbolt the steel brake line from your diff, and the bracket on the frame, then pick the car up so both wheels are off the ground, at full extension, to test.
It was free.
Matt
I cant remember if its the 80 or the 105 or both that I cut off 1 of the park brake cable mounts, as well.
Youll need longer diff breathers as well - a couple of inches. Use 1/4 fuel line.
Hope this helps.
Matt
