Hey folks. after reading some of the threads on here about SS hose failures, I've decided to ditch my SS-Teflon brake lines and return to OEM rubber ones.
Here's the first question: I have a 1991 truck, but it's got the 93-97 upgraded (larger) calipers and rotors. I bought the truck this way.
When I changed over to the SS lines, I had the short rubber caliper hoses duplicated (in SS-Teflon) by a racing shop. No problem making them, just matched them to the old rubber OEM lines.
However, I want to return to OEM rubber now and the Toyota dealer says there are two different hoses: 91-92 is one part-number, and 93-97 is another.
So I don't know which part to order. Can't take the SS lines down and match them up, because the Toy dealer doesn't have any hoses for this truck in stock. Everything has to be ordered.
If you've done this conversion, do you remember if you used your original hoses (91-92) or did you have to change the hoses to the later one (93-97) in order to fit the later calipers?
2nd question:
AND, I'm also going to return to the OEM rubber lines for the Frame-to-axle hoses as well, but the truck has a lift. I need a longer hose than the stock one. I understand there is a Toyota hose that will work, anyone know the part-number for this longer hose?
thanks
Dana
2nd question:
thanks
Dana
