This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
Is a double flare the same thing as an inverted flare?
Ill be converting my brake fittings on my rig to 3AN to keep the replacement brake lines redily available.
However, going through
Summit racing 's fittings, the have INVERTED flares, but Im not seeing "DOUBLE" flares.
Thanks.
Keith
Funds for TLCA RE DISTRIBUTED to BRC, KE7VAT
76 FJ40 "Matti" short for Matilda, "powerful Battler".
GET OFF YOUR ASS and DO SOMETHING! Join/ support and volunteer for clubs and organizations that actually fight to keep trails OPEN!
No one knows this??? Here???
Lol... Never mind. Had to search the right key words.
rock scientist..
Staff member
s-Moderator
Moderator
Yes inverted flare = double flare
"Hallucinations are bad enough. But after awhile you learn to cope with things like seeing your dead grandmother crawling up your leg with a knife in her teeth. Most acid fanciers can handle this sort of thing. But nobody can handle that other trip-the possibility that any freak with $1.98 can walk into the Circus-Circus and suddenly appear in the sky over downtown Las Vegas twelve times the size of God, howling anything that comes into his head. No, this is not a good town for psychedelic drugs."
Lol... Thanks mace!
I was looking up each individually, but not together.
Stopped at summit and got the adapters yesterday for use with SS brake lines.
I was gonna use standard rubber lines, but they don't have em long enough for the rear.
rock scientist..
Staff member
s-Moderator
Moderator
I should also note that there are multiple types of double flares. The most common two are inverted and bubble. I believe most of the tools that do double flare are capable of both types.
Vw's are bubble flare. You want inverted for everything
So I got the inverted flare adapters from summit. Not the bubble flare. I did see those two types.
