Brake Fitting Help
North Front Range, CO
Trying to install a Brake Proportioning Valve.
The valve says "Ports are 10mm X 1.0 female inverted flare".
Vendor says to use a full threaded nut with inverted flare.
Can you use a stepped or partial stepped male nut in a female full threaded fitting and vise versa?
The left is the Toyota FZJ80 standard nut. The right is the one off the ABS? Is the ABS nut a double flare/inverted or a bubble flare nut?
I assume if its a bubble flare nut you can't use it to make a double flare fitting can you?
010-2-jpg.604167
Here are some older thread pattern LC here Rainman's Brake Lines
You can see the stepped, partial and threaded fitting.
Which fitting does the 80 use, a stepped or partial steppednut?
If they say use the full thread nut use the full thread nut. The flare is all to do with the tube.
I think the 80 uses different nuts in different places. You can buy new m10x1.0 line nuts at most auto stores.
