My 69/77 hybrid pig has a real soft pedal, almost like you cannot feel anything so you push harder and harder and then all of the sudden BOOM they engage. I have tried to bleed the brakes, numerous time to see if that was the issue and it is not. I have also tried to monkey with the pedal to booster rod,(adjusting nuts) nothing. So I am wondering if it isn't my MC or Booster. When I push on the brakes as I am starting it up I feel the pedal move in slightly. Good? Bad?
If I do need to change the booster what problems will I run into; it being a 69 I believe that I have a 3 bolt pattern instead of a 4 bolt. The 3 bolt boosters look smaller/thinner then the 4 bolt. Any difference?
thanks for the help.
