Brake Failure Summary?
Central Texas
I'm coming up on 230k miles on my 2006 LX 470, trying to plan my maintenance budget for 2026. I'm combing through the brake failure voting thread and was just wondering if anyone can give me the cliff notes on:
1. Is it an issue for my model year?
2. If so, do I just buy the master cylinder and brake booster assembly or do I need the abs module as well?
3. Is there any test to preform on the system to let me know if replacement is needed?
TIA for any input, links, or resources.
Got this from AI
Yes, brake system component failure, specifically involving the brake booster and master cylinder assembly, is a known and relatively common issue for your 2006 Lexus LX 470 model year. The issue often presents as a loud, annoying alarm/buzzer, dash warning lights (ABS, VSC, Brake), and a change in pedal feel, all of which point to a failing pump motor or internal leak within the assembly.
Here are the cliff notes for your questions:
  • Yes, the 2006 LX 470 is among the model years known to experience issues with the brake booster/actuator assembly. This is considered a common point of failure on high-mileage vehicles of this generation, with many owners reporting issues around or after 200k miles. The problem is related to the integrated electronic brake control system, which differs from traditional vacuum boost systems.
What parts do I need?
  • The most common and recommended course of action is to replace the entire brake booster and master cylinder assembly as a single unit. The system is integrated, and the internal components (like the pump motor, pressure sensors, and seals) often fail in concert or are difficult to service individually.
  • The ABS module (actuator) is part of this integrated assembly. You generally replace the whole unit to address the problem effectively.
  • Purchasing the complete, genuine Toyota/Lexus OEM assembly (part numbers often around 47050-60010 or similar) is highly recommended for reliability, though expensive.
Is there any test to perform?
  • Listen for an alarm/buzzer: The most common first sign is a persistent or intermittent high-pitched alarm coming from under the hood, particularly when starting the vehicle or applying the brakes. This indicates the brake booster pump is struggling to maintain adequate pressure in the accumulator.
  • Check for warning lights: Simultaneous illumination of the ABS, VSC, and brake warning lights on the dashboard is another clear indicator.
  • Scan for error codes: Use an ODB-II scanner to pull specific diagnostic trouble codes (DTCs). Common codes associated with this failure include C1223 (Malfunction in Antilock Brake System Control system), C1241 (Low Battery Positive Voltage - sometimes triggered by the failing pump drawing too much power), and C1246 (Master Cylinder Pressure Sensor Malfunction).
  • Note pedal feel: A change in the brake pedal feel, such as it becoming very hard or feeling "limp" after several applications without the pump running, can also signal an issue with the assist.
Proactive replacement may be an option given your high mileage, but typically owners wait for the onset of symptoms or codes before committing to the costly repair.
Uhhh... that was awesome- thank you @medtro ! Why didn't I think to do that? Great info
I just want to add that I believe catastrophic failure is rare. Almost always there are some warning signs, pump making a terrible noise, 30+ second run times on a cold start, pump kicking on more frequently than it should, ect.
I really suggest reading the thread that is stuck up top, a wealth of information.
