Brake Booster pumps continuously and overheats
Hey l3n0x and CruisingAndy, did you guys ever get to the bottom of it? I've got a C1254 code and am also seeing the reading as "too low" in techstream.
Cheers!
I haven’t looked at mine since, but it seems to be working fine (it stops the car).
HDJ100 1HD-FTE VX ex-UK
Sorry for the long thread but I'm pulling hair out and would hate to go bald over this. Here's the problem and also some background on my car and what we have done so far. Any and all ideas very welcome ! Thanks
Current problem:
- The Brake Booster motor (47070-60010) is overheating, due to the brake booster motor coming on (pumping) too often.
- The motor comes on even without the driver having pressed on the brakes.
- There are no errors appearing in vehicle diagnostics (Techstream).
- After some time, due to the Brake Booster motor overheating, the brakes will fail.
- There are No visible leaks on any brake lines! No ABS buzzer or ABS or parking warning lights.
Tools / Spare Parts used:
- All spare parts are genuine Toyota parts, purchased from one of the dealers of Al-Futtaim motors in Dubai, UAE
- Techstream has been used for Air bleeding and diagnosing errors.
How to reproduce the problem:
- Bleed the brake system with manual bleeding and air bleeding (front only)
- The vehicle behaves normally and brakes feel OK.
- Drive the vehicle for several hours in some traffic and also long distance (total driving time is approximately 3 hours)
- Brake booster still appears to behave normally. According to my observation, this "normal" behaviour means that the motor will come on either when:
- a) vehicle is stationary and brake is pressed 2 times
- b) vehicle is moving and brake is pressed 4-6 times
- Leave the car parked overnight.
- Drive the car again in some traffic the next day.
- Stop the car, check the brake booster. The motor is now coming on even without the driver having pressed the brake pedal. And the motor (and accumulator) are getting very, very hot.
How to get rid of the problem (temporarily):
- Brake booster behaves normally until you repeat the above steps to reproduce it (ie. drive the car for some time).
Background on the repairs which we have done so far:
- Brake warning lights ABS and Parking Brake and BUZZER came on and brakes lost functionality in July, 2015.
- Replaced Brake Master cylinder (47025-60022, only the master cylinder, not the complete unit) in October 2015.
- Brakes worked for a few weeks then ABS warning light coming on again
- Replaced Brake Booster w/Accumulator (47070-60010) in November, 2015.
- Brakes worked for a few days and problem started again. This was the first time when I paid attention and noticed that the Brake Booster Motor was getting very HOT. The Accumulator Assy is also getting hot, I assume due to heat conduction from the motor.
- After this, we have tried various replacement parts:-
- New complete front calipers (47730-60090, 47750-60090)
- Replaced all All 5 Flexible Hoses (90947-02A09, 90947-02A13, 90947-02A10, 90947-02A21, 90947-02A27)
- Replaced ABS ECU (89540-60070)
- Replaced Rear Brake Cylinder KIT (04479-60060)
- Even replaced the engine-side steel brake lines and joints, since we were fearing that air was getting in somewhere.
Other tests done:
- Car was parked, started engine from cold start and engine left running on idle.
- Immediately after switching ON, the Brake Booster pump was coming on (was pumping) for 7 seconds; and going off (stopped pumping) for 15 seconds
- After 1 hour of idling, the Brake Booster pump was coming on (was pumping) for 13 seconds; and going off (stopped pumping) for 8 seconds
- Car was switched off and parked for the night.
- The next morning, the Brake Booster pump is pumping for 11 seconds and going off for 7 seconds.
- Start the engine and drive the car, applying emergency brakes so as to trigger the ABS.
- Observe Brake Booster goes on LESS FREQUENTLY, going off for 45 seconds.
Hello everyone. I am new to this forum.
Unfortunately I have the same problem. Tried out several things. But the ABS light and Brake warning lights keep on showing up on the dashboard. Last two days ago I suspected the alternator and replaced it but still it's a same problem . The alternator as per the battery shop they tested with the tester was charging low 13.22v. I removed the alternator cleaned it up and checked all the diods with a multimeter but everything was fine refixed the same alternator with a surprise when started the car the booster motor was continually running not cutting out and when pumping the brakes the abs and brake lights on the dashboard went off but the motor was continually running . After taking the car for a drive the same problem started again the motor started cutting out and the warning lights come on with the buzzer alarm. Surprised what is the concern of the alternator with the brakes and the motor ? Please I sincerely need advise to solve this issue I will appreciate your assistance .
Best Regards Shabbir
Actually there are two pressure switches that control the pump.
This is what I did before to diagnose my issue:
Abs issue some work done but stuck?
If you want the 1000 page diagnostic manual, message me your email address.
Hi dear can you send me the manual on my email shmeghjee@gmail.com. it seems like i have the same problem the motor continues to come on and off within few seconds without pressing the brakes.
Regards Shabbir
