Brake Bleeding
Laguna Niguel, Calif.
I did some front and rear flex line replacement as well as shoes on my 45LV. On bleed out the old master pumped up well and the bleed out good too but after it "rests" it goes to the floor. Replaced it and am getting the same results. Any thoughts on what I'm missing. Wheel cylinders are good as are hard lines. Should be good to go. Advice appreciated.
You must be leaking fluid somewhere, or your shoes are not adjusted correctly.. Look for wet spots on the lines, master and wheel cyls. If all is dry, you need to adjust your shoes better.
Shawn
