I'm not sure the bleeder valve is clogged, but I imagine it could easily happen if your fluid is old and full of crud. If that is the case, I think I would remove it and try blowing compressed air through it to clear the blockage.
However, I'm not sure it is clogged b/c I'm not sure you are following the correct procedure to bleed the system. I'm not sure any fluid will be coming out if your buddy is just holding the brake pedal on the floor before and while you open the bleeder valve.
Check the FAQ and do a search, and read the FSM for more details, but here is the basic method for brake bleeding manually with a buddy.
1. Make sure you keep the brake fluid resevoir full (bleeding the Master Cylinder is even more involved). I suggest filling it to just short of over-flowing before you start.
2. connect a hose to the bleeder valve and put the other end in the catch receptacle of your choice, partly filled with brake fluid to prevent air from returning up the line. IIRC FSM says start at the Rear Right, then Rear Left, then Front Right, then Front Left, then LSPV - and don't forget the LSPV!!!!!
3. Have buddy pump brake pedal to get some pressure in the system, then barely crack the bleeder valve and instruct your buddy to mash the pedal to the floor and hold it there.
4. When fluid stops coming out of the hose (while buddy still has pedal on the floor) close the bleeder valve. Then buddy can release the pedal. This prevents air from being sucked back into the system while the bleeder valve is opened. Repeat this until no bubbles/air come out of the valve (clear tubing helps see this), and only new clean fluid is coming out.
5. Move through the bleeder valves per the FSM - the LSPV is especially important and a known culprit of trapped air.
6. Enjoy beverage of your choice and thank your buddy for helping (maybe even share beverage with your buddy).
