Brake and power steering problems solved
Oregon
Website
www.brian894x4.com
My power steering used to whine like mad whenever I drove off road. It was fine on the street, but whenever it got bumped around and especially when in 4 low on steep grades, it would just howl and then continue to howl for quite a while even after I stopped.
I guess the fluid was just bad, because after I flushed it, it's been totally quiet, even after several off road trips. Not a peep out of it. The old fluid only had about 90K miles on it and I've never replaced power steering fluid in any my rigs, including my SAS Toyota pick-up with about ~220K miles on it. So, I'm wondering why this LC's fluid failed? This rig has never been off road before I bought it. But I'm glad the fix was a simple fluid flush and nothing worse.
As for my brakes, after I bought this FZJ80, the brakes were super mushy, didn't stop worth a crap. The typical LC80 sucky brakes complaint. The PO had the front brakes done by Midas. And that meant all new calipers and pads up front and new rotors. So all aftermarket stuff.
I figured the idiots at Midas didn't properly bleed the brakes, which was true. A proper bleed, which is a story in and of itself, did solve some of the mushiness, but not all of it. The dealer suggested adjusting the master cylinder rod to pedal connection (whatever its called). That helped more. I'm not sure why as I'm pretty sure the master cylinder was never removed before then.
But the biggest improvement of all came today...after I yanked out the crappy aftermarket pads and installed brand new Toyota pads front and rear. I was stunned. Brake response is almost perfectly normal now. I would say that braking power is darn close to stock and that's with all my mods, 33s and extra weight.
I agonized over whether I should go 100 series pads. I decided against it, because my rotors are not OEM and I wasn't sure if there'd be issues. I figured I couldn't go wrong with 80 series pads, so that's what I got.
I can't believe aftermarket pads could be so crappy. By the way, the old pads still had about 90% left on them. Someone on here, in one of the dozens of brake threads I read, wrote that pedal feel is largely based on the pads. In this case, I think they were right. I'm glad I decided to just replace the pads with OEM instead of redoing the entire brake system as that solved much of the problem alone.
But at some point I may add OEM rotors and calipers and possibly steel brake lines, but I'm pretty happy with the brake performance, compared to what it was before.
The lesson here is for some reason, these Land Cruisers really need OEM parts. Maybe its just because of the excess weight and this older type of brake system just needs the best parts possible to perform as designed. Whereas a lighter car or truck, inferior parts would be less noticable. I don't know. But if you have brake issues and cheap non-OEM pads, you now know what to do.
Good work; next on ur list is DBA rotors and FJ100 pads up front; that really helps.
