Hey guys I am just considering my options as far as suspension and my rear links go. At this stage I know I am going to be using Evolution Machining & Fabrication Inc. heim joints (medium size). What I need peoples opinion on isif my mounting location for my shocks will work.
On the following picture you will see 3 mounts the top left the bottom middle mount and the bottom right mount. The bottom right mount will be cut of as it is the old mount for the panhard rod, and the new mounting posiion is not finaised yet. The bottom middle mount is the mount that I plan on using for my soilid alloy links and heim joints.
The top mount is the one that worries me. What I plan on doing is mounting my 16" coil-overs to it, and then inverting the shocks so that they mount almost in the same position above the chassis on a custom cross member.
As can be seen in this picture the layout of the upper and lower mounts. QUESTION (finally) does anyone see any issue if I brace the diff upper and lower (with some 6mm wall rectangular tubing)?
Cheers Guys,
DAvo
Cheers Guys,
DAvo
