So after the installation of my BP-51 suspension (see BP-51 Install Complete thread), I have determined that the preload on the front struts is set at the factory setting of 20 mm which is for a diesel LC with a front bar and winch. My 200 is gas (U.S.) with T13 bumper only (no winch). The install instructions say the setting should be 5 mm and that should provide 40 - 50 mm lift over stock (not exactly sure what my actual lift was but believe its more than 50 mm). The manual also says that the front wheel drop should be 2.5" (63.5 mm). I lifted the front and could raise the frame about 3 1/8" (79.3 mm) before the wheels lifted off the ground so, 79.3 - 63.5 = 15.8 mm more than the target wheel drop spec.
Is the additional 15.8 mm of wheel drop directly related to the 15 mm error in setting the preload? Seems so, but I am having trouble making my brain understand the physics here. I don't understand how less preload would make the wheel drop decrease. In my head, it would go the other way if it did anything at all. The preload and the actual weight of the front set the resting height of the truck. If all I did was add weight to the front to get it to drop 15 mm from where it sits now, and then jacked the frame to measure the wheel drop why would it be any different than it was before I added the weight?
Why does the actual load (preload plus truck weight) change the unloaded length of travel (wheel drop) of the strut?
