bouncy temp gauge
Hellertown, PA
Hey all:
I have a temp gauge (on a 74 with stock everything rebuilt top end engine and trollhole carb and stock fan and pretty new 3 core radiator) that sits at zero when the truck is off and goes up to 100% after a bit of driving, but then sometimes drops back to zero while I'm driving, and then pegs out again. I know the truck is running just fine temp wise, but wasn't sure if it was the gauge or the temp sender itself. I just wanted to see if anybody else had an similar issues and what they looked at first before they started replacing stuff.
Any help would be appreciated. Thanks!!
The easiest to check is the temp sensor. Remove it from the head and check it's resistance cold then hot (pan of water close to boiling). The FSM has the resistance values for both.
After that it's much more involved - pulling the gauge cluster, checking for a short in the wire.....you get the drift.
Good luck
Good luck
Sounds like a plan. I’ll update after I give it a boil!!
