Bought a locked 93'..... Sort of?
Phoenix, AZ
Bought a White 93' with cloth with 135k miles recently. Not much to go on for maintenance, checked code k294 and Vin check in multiple places throughout the truck. Looked underneath for rust and verified the rear had a locker. For whatever reason didn't check the front. Go to baseline and realize the front locker has been removed and replaced with a standard non locker. Not sure if the guy didn't know any better and didn't realize it was out or he just slipped it by me. In any case, it's my fault for not checking, that said I've owned it now a couple of weeks and did a bunch of work getting it running like a brass top.
Question for you experts. If the front is disconnected because there is no locker, would the rear even work at all? Is there an interlock that would prevent it from functioning. Right now just the standard flashing on the rear. Center diff locks 4.0.
Additionally: Could this cause an abs light that always seems to turn on exactly 10 seconds after wheel motion? Right now it fails for both the front sensors which I've removed and cleaned. Thanks for your help.
K thanks for the reply. I've owned a 94 with lockers that worked senselessly after running them several times a week.
The clicking sound that I heard from them working with the old 80.. Was that a relay or the actuator engaging? I don't hear anything with the rear right now, but trying to resolve anything I can without opening up the rear.
Does it have the Pin 7 mod done?
ABS light comes on when CDL is engaged.
Can I get a recce for these plugs under the driver dash and kick panel? The second picture, the plugs were found unplugged, so I plugged them together temporarily to see if they would fit together.
