Bottom out rear shocks
Richmond, VA
I have 3 1/2" FOR lift, rear shocks are 12" BDS.
The rear shocks bottom out way before I will hit the bump stops.
Even if I extended the bump stops 3" the shocks would still bottom.
I did eye to conversion also.
What would you guys recommend?
So even with spacing the bump stops down 3" you're still bottoming out? :eek:
How did you do the eye shock adapter? What size tires are you running?
I have not yet put the bump stop extensions on yet but when I stuff the tire it looks like a good 4" away
I could be wrong.
I am running 33's
They are the standard eye adapters like MAF sell. Pretty standard stuff.
With 33's you are most likely sitting right around 14" or 15" from the stock location when fully compressed, if you haven't adjusted your bump stops down.
By doing the bolt in stud to eye adapter, you are losing another inch, meaning that 14"-15" just become 13" to 14".
Your have three choices:
1) Run a really short body stock. You won't have much travel, maybe in the 9" to 10" range.
2) Adjust your bump stops down. You're trading up travel for down travel, which means you might have nice down travel but won't have much up travel.
3) Do a stud/eye conversion similar to what I did for my Pro Comp's.
You can do what I did in the front, which was really clean and easy.
Even with that though you are only going to be buying yourself about 2"-3" or so (getting rid of being spaced down about an inch, plus going up about 1"-2"). You may still need to adjust your bump stops down a bit.
You could go up a bit higher like I did:
attachment.php
That should buy you the room you need. I went up 3.5" (to the bolt hole, 4" at the very top), but I have a 1" body lift. Between getting rid of the bolt in adapter, plus going up 2.5" without a body lift, that'd get you 3.5", which I would be surprised if that didn't give you enough room for your 12" travel shocks.
Having the body lift makes it way easier to work up there, and the extra inch of room is much appreciated!
Do you have the specs for your shocks (min/max length)?
I do not remember the specs off hand but I am going to mod the rear upper mount get a few more inches I do know that the shock body is definitly long.
Either way I have to do something it is just a matter of what.
A 1" body lift would be nice because there is like no room up in there but I will get it to work.
out them and then extend the stops and I should be good.
I just have not figure out how I want to mod the mounts.
Your rear design looks ok.
I think that FJBen did something as well, I am going to search to see what he did as well.
I will post picks when I figiure out my mod design.
Pull the shock and measure the length when fully compressed. Technically you measure from the center of the eye to the center of the eye.
Without the min spec your working blind. You may have a shock where the min length is unreasonable to fit. You just won't know until you measure it.
