Booster Push Rod Length?
Golden, CO
Replaced my booster today. The old one was failing slowly. Anyway, I set the length of the push rod by putting a thin layer of grease on it and then setting the master on top with the gasket. I adjusted the rod until I saw a little grease in the master, then I backed off a little.
The weird thing is that the push rod has about 1/8" of play in and out. I assume I was supposed to measure with it pushed in, but the FSM doesn't mention this. Anyone know what that's about?
Match it to the length of the pushrod on the booster you removed. They should be identical.
I am pretty sure the play should resolve when vacuum is applied (when installed on the firewall).
I noticed that play as well when I replaced my booster. I measured the rod length (including free play) using the method grease method described above. While my brakes work fine, the brake pedal free travel is out of spec a little (too much travel), I suspect because of including the free play in the rod measurement. If I were to do it over again, I would push the rod in (not include the free play) and take my measurements from that instead.
As previous poster mentioned, it's a good idea to compare length against old booster.
I did compare to the old booster. The new one seemed to have a little more play (it was a different brand) so that made it confusing. I matched it to the old booster with the pin all the way in. that said I didn't have a really exact way to compare them so I could be off a bit.
The brakes seem great so far. I can't detect any signs of dragging, but I don't really know how that will show up. The brakes didn't seem abnormally hot. They do apply quicker, but I assume that's due to new fluid and a new master. The old fluid was starting to get pretty dark after a couple years.
Sounds like you fixed - good job. I replaced my master cylinder and flushed the old fluid as well. All seems to work fine.
I looked at how the old master and booster were set up today. It looks like there was a decent gap, more than what I set up with the new master and booster. The old master had a decent pocket worn into it over the years, but I wonder if there's maybe some variance in the depth of the master cylinder? Whatever the case the brakes are really better than they've ever been.
