Boost/Vac Gauges
I am trying to educate myself before I install a SC kit, and starting with a knowledge base of zero.
Why are so many boost guages also boost-vacuum gauges. Does a Super Charger ever create a vacuum ? What senerio produces a situation where the operator would need to monitor boost/vacuum?
I am still looking into the science behind why the S/C creates a vacuum, but I do know at low RPM it does create a slight vacuum and seems to increase gas mileage slightly. I'm not sure at what RPM the 1FZ-FE goes into boost with the TRD kit because I have not bought any gauges for mine, but I know that the maximum boost is about 9psi or so.
AFAIK it seems like most people use boost gauges just to monitor if the blower is functioning properly since there is really no accurate way to know if it is or not without a boost gauge. For such a low amount of boost, I have read that having a boost gauge is not extremely critical, but probably something that is nice to have.
I used my extra funds to buy an LT MAF and a scangaugeII for the time being. Guages and custom intercooler will be in the future as funds/spare time allow. I haven't sourced a new maf sensor and the scangauge hasn't arrived yet so I will post what my results are in the future.
I forgot to mention, that the S/C install is relatively a piece of cake (less physical work than an OME install, but slightly more time intensive) IMHO if you follow George's page and some of the other posts on here in regards to the crank bolt. Best of luck!
