Bolt Torque ??? Help............
BEND,OR
I'm starting to reassemble the tranny and transfer case covers and plates after installing new seals and gaskets and the HAYNES manual is terrible about giving the various torque values.
Most of the bolts have a # 6 on top of them . I assume that is a grade 6 bolt. I was tightening some of the 8mm bolts to 25 ft/lbs and it was to much for them. One twisted off and broke !!!! Is there a standard torque limit for the various sizes that I should know. Most of the bolts I'll be dealing with are 8mm, 10mm, 12mm.
You need to use the Haynes manual you have for toilet paper and get yourself a real shop manual. You might find it on the birfeild.com website. My '60 series manual also covers the older single peice transfer and I KNOW that manual is available on line, I don't know if the older one is or not.
Yes, torque values are size-driven, not by what they are fastening. I learned this the hard way......like you did.;)
Ed
