bolt size needed
georgia
could one of you guys tell me the size and length of the front axle, rear control arm bolt? the reason ask this group is, MAF doesnt know the bolt sizes they supply for thier drop brackets, and yes i talked to the tech dept. i even called up the local toyota parts counter and they said that the parts IPC doesnt give a size just a part #.
the reason i want the size is i'm going to change the 8.8 or is it a 9.? that MAF ships, to a 10.9 grade from CAT.
thanks in advance
Call CDan, he'll be able to look it up.
thanks Brent. just called and got the info from dan the man in the desert land. its an 18mm bolt x what i can measure and convert to metric, a 89-90mm length
