Bogging and sputtering when cold; code 25/26, 83 and 84 NEED HELP!
Hey Guys,
I've been going down what seems like a rabbit hole with my problems on my 80. A quick up to speed; it's a 94' I've had for 10 years and in December I had to put a newer engine in it, one with 160k instead of what seemed like 500k. Within a month I had a head gasket go bad and over the past 30 days I've been trying to run down some issues that I can't seem to find the cause of.
I have been getting intermittent CEL on and off for a couple of months, no real patterns to speak of, but it would usually go off coasting down hill. I didn't worry about it much until it began staying on longer about two weeks ago. Then, it stayed on. When I checked it I got codes 25/26 and 83/84. I've read everything I can her on Mud and I'm either confused by too many conflicting posts or i'm just confused, not sure which is my problem yet.
I do not have a 93', so I am doubtful I have the typical ECU issue related to codes 83/84. So, any suggestions on what to try would be helpful. I have not had any real indications of any tranny issues, until today, but the light has been on along with 25/26, so that didn't make sense. However, today, when accelerating to get on the highway the 80 seemed confused for a few seconds with what gear to be in and seemed to downshift twice at about 25-35 mph. It downshifted to what seemed like 1st gear and the rpm's jumped to over 3500. I have not had that happen before and now I'm super stumped. Any ideas?
As far as the 25/26; I just installed new O2s. Mine were already about 8 years old, so even if this wasn't the cause they needed to be done. That did not fix it. After resetting the CEL by pulling the ECU fuses the CEL came back on within 100 miles. Same codes; 25/26 and 83/84. I have pulled my spark plugs and discovered some were not gapped properly, so I re-gapped them. They all had black around the metal rim, but were more whitish on the tips. So, there's my 25/26 proof, I guess. Yesterday, I also pulled my EGR and cleaned it. I have no idea if that is the culprit, but that does not seem to have helped. I don't know if it is stuck open, closed, or if it's fine.
Within the last week the 80 has struggled up hills without downshifting and flooring it, even when the car is pretty warm. In recent days when I first start it up and pull out of my garage it literally won't go up my driveway, which is somewhat steep. The 80 bogs and sputters and just won't move. Today, it did the same after starting it up, but ran ok through the mountains (it does seem weak, though), but after I parked it and it sat for about 35 minutes I came back and turned it on and it idled ok for about 3 minutes, but then began to buck and bog and literally stalled. I've never had that happen. No CEL yet, which is weird to me, but I don't know where else to look and what to check.
I'm desperate for any help. If you guys can give me some advice or some guidance it would be awesome. I've been buiilding my 80 so I can take my kids on longer adventures, and our first is next week. I can't drive it the way it is , even to the grocery store.
Thank in advance,
Chris
I should also mention the OD light was blinking on/off for about 10 minutes yesterday. No CEL at the time, just OD flashing, but then stopped and has not come back.
For anyone out there reading this... tonight I pulled the EGR again and taped up the main ECU harness with electrical banding and heat resistant wrap after inspecting it and finding no broken or frayed wires, but the heat resistant wrap from the factory had deteriorated. I also pulled the intake tube for inspection and found nothing alarming, but ordered a new tube anyway. Should be here tomorrow. I'm doubtful that is the culprit.
I'm not sure what else to try at this point. It seems like my problem has deteriorated over the last couple of weeks, so I believe it is something that is either blocked and getting worse, or some sort of electrical problem that will eventually fail, but is only dying a slow death. I could be wrong, but each time I drive it the problem gets worsens.
Any ideas?
I had poor running on mine, I think due to water contamination in the gas. Put a bottle of heet in helped quite a bit. I don't think I had any codes at the time though. It would bog down real bad when I tried to get on the freeway.
Thanks guys. As it turns out, my issue was all related to poorly gapped spark plugs and possibly cracks in my intake tube. I swapped in brand new NGK's (Densos were not liked by the 80) and bought a new intake tube=problem solved.
I take it back, it isn't fixed. The problem returned this morning. I don't know what to do, but now I think I may have another issue as well. While trying to determine if anything was lose or shorted, while the 80 was running I was checking the connections on the distributor cap and when I pushed in the center connector I got shocked. Is this normal? I can't imagine so. I checked my battery ground and it is a solid connection from - terminal. What happened here?
