bodywork question
I looked into this but decided to buy a sandblaster instead (which was a mistake). Typically what is prefered is a caustic solution with electric current to remove the rust. From what I remember this is far from cheap. Hemmings used to have some advertisers for this sort of service.
The problem with acid is that it will also eat away the metal.
You might want to consider this:
http://www.sibleyengineering.com/pmb.htm
Not this particuliar company (unless your close to them of course). I don't know what your trying to do, but this will get the surface clean without damaging it. PMB will not take rust off though, you / they would have to go back in with sand or grinder.
Hope this helps, Matt
I want to do this with my cruiser. The quote I got was about $500 for all the body parts. Its awesome because it gets into all the nooks- all the places the sand blaster cant.
If youre close to the San Francisco Bay Area, there is a place in San Mateo that can do it. I forget their name at the moment, but they are right off the 101, just north of hwy 92. You can see their building from the freeway on the west side.
-Dustin
Just a warning. I have had body parts "unpainted" here in Atlanta. They do a great job.
But the paint is gone from inside the body panels as well (windshield frames, hardtop sides,
doors). Unless you have a sure fiire way of getting paint back into the inside of the panels,
]I would not have these parts dipped again. There are some places that still do electro-
galvanizing and that would be awesome -- unpaint and then galvanizing and then primer
and then paint. As close to rustproof as you are going to get.
I fully agree with rgentry.
We had my brothers muscle car dipped and now it is rusting from the inside out "because it gets into all the nooks- all the places the sand blaster cant." This is a good property of sandblasting because it won't get to the places you can't get paint on.
I would never do this to a car again.
NUT
Strip n dips are about $1.50 per pound. It would be good for a frame but I concur with rgentry, don't dip it unless you can repaint all those 'nooks and crannies'.
