Body Question
Goodlettsville, TN
Are there major differences between a 70 and a 78. I have a 78fj40 with major rust issues from the floor pans back. It is at the point where I am probably going to have to find a different tub or go with an aftermarket. I have seen a 70's tub for sale and am wondering would it mount to my 78 frame and cowling without major modifications?
Edit: sorry, thought you were getting a newer body when I type below not the other way around...still a couple things you’ll have to address.
I put a 76 body on a 74 frame. Had to redo the back end for the barn doors, vice ambulance doors. The front doors required different strikers. The tire carrier changed. The parking brake handle and cable routing changed, but if you keep your cowl this probably wouldn’t apply. Not sure about the fuel tank in your case. It went from inside to outside at some point. My old hardtop/roof/windshield bolted on, but certainly took more effort than the original body. I’m hoping it “learns” it’s new home.
Modifying the ambulance doors and tire carrier are not that big of an issue. My fuel tank is still inside, so that will not be an issue. Mainly just want to know that the length and width of tub are the same, that the floor pans and center hump will still line up with cowl and that the frame is the same and want need any modifications. Thanks in advance for any help
Subscribed. I'll be attempting to swap a '72 tub onto a '76 frame in a few years so thanks for asking the question. I'm going to watch this thread to try and learn a few things. I don't have much to add other than what I've read and observed between the two (I have the '72 sitting in a barn right now). I believe in terms of width and length they're identical, and from the B pillar back, they're almost identical. Differences I know of so far are:
  1. The 3 speed trans hump is smaller and doesn't fit over the 4 speed without some modification (as Downey mentioned above)
  2. The opening and stamp where the steering wheel wheel passes through the firewall is quite a bit different. Dash key and switch locations are different too. The latter could be patched, welded and drilled out to match a '78 I think but the firewall differences are the main reason why I'm going to do everything i can to separate it behind the A pillar, or even the B pillar.
  3. The spare tire location will need to flip and be modified. I think the reinforcement with captured nuts behind the quarter panel will have to be added or fabbed.
  4. Reverse light hole needs to be filled.
  5. Gas tank doesn't have the lid cover. That can be left as-is or cut out and patched in.
  6. '70 was bench seat, and I believe the seat frame holes will have to be tweaked for '78 buckets.
  7. The rear sill will be different.
  8. My understanding is the body mount locations are the same.
You can get a good idea of where the break in years for various sheet metal pieces happened at Real Steel Cruiser Parts.
I'll hang up and listen!
Just to clear, you ask about the differences between a 70 and 78, and talk about a " '70's" tub for sale. IMO, the biggest PITA would be an early tub without provisions for the brake booster. The firewall rib on early tubs runs straight up past the brake m/c and interferes with a booster. If you want a brake booster it would require cutting out part of the rib, or using a adapter/spacer to move the booster out past the rib, which can cause clearance problems with the carb if you have a F engine. Removing the rib weakens the firewall causing unwanted flex (yea, some PO left it to me to make one right).
Otherwise, I've swapped my share of tubs, and:
The steering column through the firewall is an easy fix.
I run a '76 gas tank cover on my '72 tub (love nutserts).
Nutserts will work if you're not concerned about the seats coming out in an accident, but adapter brackets that use the OEM mounting locations, and reinforcing plates under the floor where OEM holes aren't convenient, will get the seats in.
The rear opening IS different, early tubs do not have a recess to accommodate the ambi doors, but there are ways to get everything to fit.
The rear door hinge locations ARE different.
The GOOD news? The body mount locations ARE the same.
