body movement?
5,280 ft
Website
www.dadirriextracts.com
Alright not sure, but the body mounts right behind the rear shocks look like there is no bolt in either one!. I was measuring the frame to tire trying to check and center the body over the axles via panhard rods. The body wall in the rear wheel wells on one side does not sit the same on both sides! is this ok??? Coulda been like that for a while but Im not sure. The farthest rear body mounts are ok, but it looks like the ones in front of it have shifted a little. Hmmm...any thoughts fellas? Thanks
J
picture?
This is normal.
J
My body is also crooked like this as well. At first I had the panhards aligned with the body, however this didn't turn out to be so good. I kept hitting twanging my front spring on the bump stop cup. I've since aligned the axles with frame and things are better.
I've been tempted to loosen all the body mounts and try to shift the thing straigh but haven't done this yet due to the work involved. I'm curious to see if anyone has some thoughts on this.
I also have this issue... Any thoughts as to how one might correct this?
-hkimsoft
remove them or let them be. Unless you have some serious fat arses sitting in the back seat they are there as an additional cushion/support like with pickup beds. I removed them with the body lift and noticed no difference.
This is normal.
After loosening all the body mounts, how do you shift the body straight? I don't mind the work involved... just looking for the steps of doing it. Anyone?
Thanks in advance.
This is true!
I've had this problem but was able to correct it with some patient adjusting of the panhards.
Kalawang
UHH, no you didn't. We are talking about the centering the body on the frame. Not the frame/body over the axles.
Instead just worry about centering the frame over the axles. I have talked to Ben at Slee and he said to use the frame as reference points and not to worry about the body at that particular point.
I dont see how I could make those particular ones line up if they are not now when the very rear crossmember mounts are bolted in place correctly. You would have to "bend" you body to line them up.
I figured picture would help... As you can see body is slightly shifted to left from the frame. BTW, frame to axles are straight.
I was looking for a way/trick involved/procedure loosening and straightening the body to the frame... If there is no easy way of doing it, I guess I would have to live with it.
Thanks all!
I gotcha.
What you'd need to do is loosen all your body mounts and muscle the body over a smidgen and retighten. It's really not too bad and with the right persuader you could do it alone or find a friend to help. Just be sure to measure each side. Pick a few locations on each side (the same on each side) and measure from the frame to the body, make both sides the same and you're in.
Finally got extra time in hands and decided to do this... I have loosened all body mounts and tried muscle it to shift little to the right... no luck... it won't move... is there any trick to this?
Come a-long and a tree and your body wil move where ever you want it to...
Beno, here is a novice question... where would you hook it to without damaging the body? btw, I found the tree... ;-)
I'm definitely not an expert but you could move the body ever so slightly by taking a couple of comforters, placing them around your B pillar (with your windows down), then take a tree saver strap and put it around the B pillar, then take one end of the come along and attach it there. Then the other end of the come along goes to a tree saver around the said tree that you have identified.
Try to anchor the body on the other side to another tree or something else that is immoble. That way your body won't lean as you crank on the come along--very slowly and very gently. You are just looking for a couple of inches right? Since your body is not mounted on the body mounts it should move. You might want to also be care full about shifter linkages as well....
Anyway, that probably the way I would do it....then again, if you have some cash, a body shop might do it for a few hundred bucks on a frame twister....
-o-
Thanks beno... I will try what you recommended... need to move 1/2 inch to the right...
