Body Mount Torque
Kelowna, BC
Anybody know offhand what the body mount torque should be approximately the BJ74 (no can find in FSM). The M10 (1.25 thread) Grade 8.8 bolts are 38 ft-lbs in the FSM, but no reference to those used for the rubber body mounts. It seems 38 ft-lbs is really squashing the rubber mounts OR are the bushings inside supposed to take up the torque. Thanks for any help.
Not sure on the torque # but they are tightened until the body mount rubbers start to compress and then a jamb nut is used to keep them tight. You can use medium lock tite as well for back up.
Thanks - regular bolt 38 ft-lbs and flanged bolt is 43 ft-lbs -- so decided on 40 ft-lbs for M10 (8.8.)
