Body lift pros
I think there are some pros to running a body lift for my long term goals. I am not talking as the sole form of lift on a vehicle
Side benefits unique to what I want to do
1. Easier fabrication of strong sliders. Less angle to get out and around the rockers.
2. Alows room to raise fuel tank and install an aux tank up higher or run a bigger aux with the same clearance.
3. #2 Allows room for some custom suspension stuff I want to do like triangulated rear 4 link sans pahard. Many reasons why like moving axle back a bit and tuning things like articulation and antisquat etc.
Not unique
4. If a rig had the right width (or wheel offset etc) say 35' tires and was only rubbing the back center of inner arch of the well they could add a 2" body lift and swap the 2" bump extender for a much thinner one.
5. With say 35" tires 4" suspension lift with 2" body nets the same suspension travel as a 6" suspension lift with less stress on driveshafts and less caster correction needed. All with a lower COG than the 6"
Hmm
http://www.4crawler.com/4x4/ForSale/ToyotaLandcruiser.shtml#FJ-80
i have a 3' lift and 2' body lift and love it.
COG is down lower, i can run 36" tires that dont rub.
more room for bigger zorst.
if any one is thinking of doing it go ahead and do it, there easy to do and i love it
You have 5' of total lift? :flipoff2: Body lift is in my things to do list. ;)
other advantages -
1. Shock mounts - it's much easier to extend them for some real long travel shocks without the body in the way in the back, or the brake master in the front (though the front can be done without, it does give some extra clearance).
2. Exhaust - I've tucked mine up higher at the cat since I have the extra room, and I was a little close on my slider out-rigger to the cat. You can also go over the frame rather than under - though I haven't and I think my 1" is a little short for over the frame, but I've read of someone doing it with only 1" body lift but never saw photos of routing.
I'd suggest doing the body lift first, then building your bumpers - if you're not buying them. My front was made for no-body lift, and it doesn't look bad, but could have been slightly closer had I known I was going to do the body lift before I ordered it, I would have had some changes made.
At 1" adjusting the shifter was no problem, but my transfer case shifter hits a little bit in low. Not enough to justify making changes for it, but you might run into more issues if you go more than 1"
I sourced mine from 4crawler too...
It looks pretty simple to make a new bracket to Modify the front bumper. I have a plasma cutter I can use at a friends place. For bigger projects I just borrow it.
It also can allow more room for a spare under the rear. Space the stock bracket way up higher or make your own low profile rack. Look at the space between the stock one and the floor pan w/o a lift. Then add two inches and fab a thin stiff cross member. Skip the winch and use a twin handle "spinner" type hold down like on a desert trucks bed mounted carrier. $ says with a smart fabricator a 315 will tuck up there nicely!
How safe is it to run on the lifting blocks?
Only as safe as the installer, rest of the truck (rust etc) and the quality of the kits.
The 4 crawler kits have been used on many rigs that get wailed on by serious rock runners. IMHO get their full kit and put it in intelligently and you are still much safer than some moron with a suspension lift and no caster correction.
I'm doing a minimum 3" lift and was thinking about fabricating some type of bracket extension and just weld it to the top of the existing ones. It will be stronger, no shifting and you can still use factory bushings. Just an idea.
QUOTE]
My bumper isn't mounted with brackets. The center section of my bumper slides right over the frame - totally enclosing it, so it's bolted bottom, top, and sides. Frankie's Off Road did a sweet design on that. But it's not something you can just space up for a body lift like a stock bumper.
