Body lift Kit
Québec, Canada
Hi,
Does somebody know is there a body lift kit available for toyota prado +/-2006.
I want it on my FJ Cruiser. I know that Artic truck put some body lift on the prado but i dont know where it take it!
Thanks!
Al
If you're in the US, it might be easier to find a body lift kit for 4th Gen 4runner, after all, it's the same vehicle underneath.
I'm not big on body lifts.. May I ask, why you want to put a body lift on a FJC? Trying to fit larger tires? Why not use suspension spacers?
You may want to lurk in Toyota 120 Home
That what i found...un body lift for 4Runner 4th generation.
My suspension is new, OME with a Toytech front space(3" of lifting)r, but there rubbing.
A 6" lift will be when the waranties will be issue.
My mistake is my Beadlock, with a bad back space! I need a another custom spacer (5/8") to clear the brake.
Bad thing is we can't try some wheel and tire to see if it fit. I read a lot and a was thinking a different back space will eliminate the spider trax spacer....No..i was wrong...the spider trax as a second fonction: distance the galiper...Big trouble!
That my stories.
