Hi all, I've just done my HG and all seemed fine until a drive of about 150 miles recently. Driving at 70-75mph everything was good, as I slowed and came to a stop at a junction I sat for maybe 30 seconds. When I pulled away there was a huge plume of blue smoke left behind. At a few roundabouts after this there was a small puff of blue smoke on accelerating.
The only blue smoke I had before the HG replacement was on startup, the new valve seals cured this.
I first thought piston rings, but wouldn't the blue smoke be there on overrun as well as acceleration?
I also thought PCV. The hose is clear (if not a bit oily) and the valve seems to open ok. Is it worth changing the PCV, or should I check the compression first to prove the rings?
Is there any drivability test I can do to prove if it is the rings as the blue smoke is only apparent sometimes.
All advice greatfully received...
Dave
Dave
