Blue Sea Below Deck panel install
LUGOFF, SC
A couple weeks ago I installed this beauty. It's wired for constant hot as it has it's own On/Off switch.
Fits there like it was made for it.
I ran a new hot line from the battery to a Blue Sea 6 spot fuse block mounted to the fire wall. That might be a little ratchet for some peeps here, but I like to keep my wiring separated from the stock wiring; makes diagnostics easier when/if something goes pear shaped down the road.
The input is jumpered across the top terminals and I ran a wire up the edge of the hood to where I mounted a pair of LED running lights in the front corners of the hood. As there are two of them and they are flood lights, shadows are nearly eliminated around the top side of the engine with the lights on. The switch is mounted through the back wall of the battery box, as its supper easy to find the battery box in pitch darkness.
https://www.amazon.com/Universal-Waterproof-Trucks-Daytime-Running/dp/B071PFC1H2/?tag=ihco-20
The reviews said they have a tendency to burn out, so I mounted them with spade lugs and zip ties over wire blocks. For 1) it will be super quick and easy to change them out if/when they go bad and 2) the back is suspended in an air gap allowing it to radiate heat. Heat being the killer of LEDs.
So far they are great and have been used a couple of times to check the MBG's oil and fluids at night-time gas stops.
Could be cool, but the pics are so small I really can't tell. :meh:
Better? or Too Big now?
The pics look real big if viewed on a desktop, I don't know about a phone.
Nice job! I'm going to put my Blue Sea fusebox in the same exact spot - I can't figure a better one. Yeah, it might not be ideal for some others, but it's my fawking truck and I'll do what I want!!!
Good job, yo.
