so...I finally get my bumper on, and procceed to mount my aux. lights on it.
I had pre-wired all the switches and relays weeks ago. I had tested the relays with a voltmeter so i know they work when the switch is "on"
so..wiring the lights, I decide to take the power off the fusebox under the hood, just behind the battery.there is a wire coming from the positive battery cable, terminating at a lug about 6 inches from where I need to get power to. Took out my 10 MM ratchet closed end wrench, and took to loosening the nut. Then...BANG! big shower of sparks. I seem to have hit some grounding point.
anyway...I blew the 120 Amp alternator fuse. and the lights dont work, and the car wont turn over.
***But I took ther power off the positive feed to the fuse box. If iI blew any fuse there, wouldnt i still be getting power to my lights?***
Or is there some sort of redundant feature that wont allow something else to work if the alternator is shut down, since any load ( without a recharging alternator ) would drain the battery.
I didnt check the fuses in line for the lights, because I think i shorted out the circuit BEFORE I attatched the power wire, but I could be wrong, since it was well past midnight when I was doing this, and I get up at 5:00 am.
now its raining, and wont be able to work untl this weekend, and its gonna be cold now.
**ck!
after replacing the alt. fuse, if i still have problems...where should I look?
**ck!
