Block Test Passed...
Usa
I am having cooling issues, multiple symptoms (see links below). First, had a TRAD radiator that split at the top (due to pressure, maybe?). Then ordered and installed new temperature sender, 170* thermostat, Aisin fan clutch, aisin water pump, aisin fan clutch, all new hoses and a CSF metal radiator. Now temperature increases to maybe 80% on the gauge ONLY WHEN UNDER LOAD. If I set my hand throttle to 2800 RPM while in park, it stays in the mid range forever. However, sitting at idle with nominal temperature, it will get to that 80% threshold within a minute of driving uphill at <30 mph.
I did a block test today and it passed.
I’ve purge air from the system (mentioned in posts below) by parking at a 30* incline and running it for and hour.
I’ve heard the “blue fan clutch” suggestions, but it’s 30 deg F here today and I am just putting around the neighborhood and this is happening. I am sure the OEM fan clutch is fine in this regard.
What am I missing?
