blinker problem (1 Viewer)
i can't get my left blinker to blink, it lights up but doesn;t blink, the hazrards work, and so does the right blinker, what caN I DO TO FIX IT
thanks for your help
john
Hogan
Three on the Tree
Forest Lake MN
I have the same problem on my 71FJ40. I replaced the bulbes no help
cruiser_guy
Good morning from here, Just finished updating ou
Wherever the truck stops!!
Website
wirrell.com
The bulb is NOT the problem if it lights. Check the wiring to and from the flasher.
Columbia, MO via Louisville, KY
x2 - use a multimeter, and make sure that you have a good ground - try grounding it using a seperate wire, b/c if the hazards flash, your flasher is fine, you just need to complete the circuit
