black grill
CreeperSleeper
Cascade Cruisers
Canby, OR
Okay, I finally found a use for that bedliner in a spray can... dechroming my 80!
Step 1: Remove grille and light surrounds
Step 2: Wash very well and dry
Step 3: Wipe down with Acitone
Step 4: Paint with a plastic primer. I used a can of Fusion I had on the shelf.
Step 5: Skip to Step 6 while waiting to dry.
Step 6: :beer:
Step 7: Repeat Steps 4 - 6 if desired.
Step 8: Spray with bedlining. *NOTE: This stuff sprays really thick! Make sure you move fast and keep the can well shook!*
Step 9: See Step 6
Step 10: Repeat Steps 8 - 9 until you are satisfied with coverage.
Step 11: Put in warm dry place to let it cure for 24 hours.
Step 12: Finish out the evening with multiple Step 6
Step 13: Put everything back on your 80!
This is how it should look when you are done:
can we get some full frontal?
Looks good, I did the same, but with duplicolor dark gray wheel paint I had laying around.
I hope you remembered to leave a note on the windshields of those cars before you left the scene ;)
good idea....looks great.....
I used a can of bedliner to do a 5 inch strip across the front of my hood where their was some chipping...stuff works great....
Thanks for the info. I have to dechrome my grill too. I am putting in a mesh insert also. (93 grille)
I am unfamiliar with the bedliner in a can.
Where can I get some.
3m ruberized undercoating works great too. Nice alternative to paint as it does not chip.
I used the Dupli-Coat brand found at AutoZone. It dries hard and doesn't leave a rubbery texture.
