BJ74 diff oils
Miami
Anybody recommend any particular diff oil ? Or just any 80w-90 gear oil will do the trick?
Cheers guys
Some of the rear diffs came with a limited slip so bear that in mind when you add in oil. The LSD takes an LSD additive. Otherwise any dino oil (or synthetic if you want) 80w-90 should work, GL5 is fine. With the transfer case and trans you need a GL4, but that is a different story.
*edit I meant to say diffs and not lockers. I needed more coffee, haha.
Some of the rear lockers came with a limited slip so bear that in mind when you add in oil. The LSD takes an LSD additive. Otherwise any dino oil (or synthetic if you want) 80w-90 should work, GL5 is fine. With the transfer case and trans you need a GL4, but that is a different story.
Thank you my man! No lockers so just gonna go synthetic
