Hi there, A few days ago I started up my truck and immediately my driver window rolled down all by itself. The driver window is now unresponsive to any commands from the master switch. The passenger window still works without issue.
In addition, now anytime I turn the ignition on, the power window relay at the bottom of the driver door clicks and will become slightly warm after 60 or 90 seconds. I haven't left the ignition on longer than that. Even if I unplug the master switch, the relay exhibits the same behavior--leading me to believe that the master switch is not the culprit.
I've tried performing holding the switch in the up and down position for 60 seconds as described in the manual. I've also tried performing the tests in described in the manual too; however, the wiring is different so I'm not sure if these results will be beneficial.
Has anyone experienced anything similar?
Thanks for any assistance in advance.
Michael
Michael
