hey guys,this is my first post here.
im having a problem with my new thermostat in my bj73 cruiser
it doesn't seem to be opening and will start heading towards overheating,i have never let it go above 95 degrees on my test drives .....here is the run down
the thermostat is a genuine toyota 82 degree with new o ring
it is installed spring down in the housing
i have bled the system
i have checked the thermostat and it is opening at 83 degrees
i have installed the bleed hole at the 12 o clock position
when i remove the thermostat the cooling system works fine but obviously it doesn't reach operating temperature
it has not been overheated
the head is sweet
i temperature gauge is working fine and i also have a very reliable aftermarket gauge
i keep thinking it must be a air lock or that i have put the thermostat upside down
any advice would be greatly appreciated
cheers
tommy
the head is sweet
cheers
tommy
