bj60 high rev????? help!!!!
whistler
hi i'm new here and have tech question. my 82 bj60 idles too high at idle when it's warm. i have adjusted the throtle cable and screw(was adjusted by a mech. was woking great before that) anything would help at ehis time.
Probably the diaphragm in the back of the injector pump. You are supposed to add diaphragm oil every so often but hardly anyone does. Both of my BJ60's have done this. The diaphragm gets a small pinhole leak in it and allows more fuel to enter the pump. It will only get worse. It is about a $25 part and a real PITA to replace. Good luck.
Generally, but not always, the diaphragm going bad causes a lowering of the idle to the point of the truck stalling. That's what happened to mine anyways.
