BJ42...sudden jolts...?
Thanks have just been glowing the easing the hand throttle, working fine. I have yet to get a hold of a voltmeter...so..unsure of voltage with no load. Running a manual line into the cab would be easy, but had better get on the electrical system first.
regards
J
Diescipel said:
What is the possibility of running a cable into the cab for manual control of the fuel control arm?
Just a thought...
Make a lever with 3 dents in a plate. kinda of a lawnmower stlye. but remember you lose the low oil px protection.
Kinda nice to have a dummie factor in there.
For your Bj42, try running a seperate wire from the edic relay to the negative post on the battery, it would be a forsure ground... just clean a spot on the relay where it bolts on and use a ring terminal. 14-16 gauge wire otta work.
Greg, I use (!!!!!!!) sometimes as part of my laughing. i always got a smile on here.
