Hi All! I have a 1982 Canadian BJ42 which I'm really enjoying now that I found myself some rear doors and got them mounted ...
Thanks to a really helpful guy in Toronto for that!
My problem, however, is ... of course ... headlights. Turns out a PO hated the center tap so much that he took it out! Gone! Fusible link, wire, yep ... just gone.
So I'm trying to source some information here. I know this has appeared in threads already, but I can't seem to find aftermarket sources of these links, Toyota tells me the parts is discontinued, surprise. What I actually want to do is find replacements for all fusible links in the truck:
Now the 3 off the 24V battery (highside) pole are present in a state of decay :
Now I don't have an EDIC motor - I shut it off with a throttle cable attached to the injection pump. I believe one of these is only for that.
And the missing center tap on the -'ve pole of the highside battery (it's the thing you can't see!):
I don't even know what gauge of wire I should be replacing the original with ... it goes to pin 8 on the dimmer relay and the "neutral" pin of the right headlamp.
So ... long story short, I can't cruise at night until I get some replacement parts! Any information on:
1. wire gauge
2. replacement headlight fusible link
3. replacement 24V fusible links
4. exact location of dimmer relay on a Canadian 82
Thanks in advance for any insight. And thanks to a fellow Mudd member who was kind enough to send me the wiring schematic for a 1981 BJ42 ... I was pretty lost without it.
These are awesome vehicles; I teach high school, and the biggest problem I am having is getting out of the parking lot at the end of the day. Teenagers out here don't often know what they are ... but they know they're special!
Thanks!
1. wire gauge
Thanks!
