Hi Guys, I'm on the final stages of my 1982 BJ42 restoration (BJ42 found in a derelict barn) but getting bogged down with my non charging alternator problem. I have read all the forums fantastic info. and thought I knew it all but still can't solve the problem. Just consuming fuses by the dozen. My 6 pin 24v. regulator was buckled in the BJ's Pyreneen escapade so replaced . However new has only 5 pins connected to the 6 wires in the loom.The fat white in the loom goes nowhere. Starting, running and switch off all work fine. The only problem is the ignition/sedimentor light remains on and I cannot detect any charging of the battery. I traced the fat blue /white wire on the alternator and it terminates in a 3pin socket next to the regulator. ie. it goes nowhere as well. As my fan motor had been smashed in the crash ,I had wrongly assumed this empty socket was the feed to the fan motor. Does anyone know where this 3 pin socket should go as it could be the answer to my prayers.
