BJ40 Wiring harness replacement
I have a 1980 Colombian BJ40 that is in need of wiring work. I’d love the fuse box updated and removal of the converter from the engine side of the firewall. I know of painless (painful) and American Motor wiring solutions.
Is there another one I should consider?​
I don’t have the space/attention to detail to do this myself so I requested quotes from a well know landcruiser shop and a local place that specializes in Toyota vehicles...the disparity in quotes has me all confused. The landcruiser shop is saying 40 hours of labor. The toyota mechanic is saying 6-8 hours and this was a similiar time period that an Aussie shop quoted on video when I was researching doing it myself? What am I missing?
@traillme, I've been rewiring Harley's for a while. Most people do not realize how much wire is in a Harley dresser. My first one took over 40 hours, my last one took 25. As I do more and more I get faster, as one would hope. You get into a rhythm, just like being a musician. The first time you play an unknown song it takes time to get thru it. The more one practices the faster one gets.
That being said, it still takes time to do the job right no matter how many one has done. The condition of your old harness is first and for most. If it's FUBAR then you are making that harness from scratch. If you have a relatively intact harness, that makes the job so much easier to copy. Other factors come into play as well. Are you going back with stock connectors, are you waterproofing the connectors, are you hand crimping those connectors or using a specialty tool that cuts the crimping time, hand wrapping the wire with electrical tape, or using a Painless type wire loom that slides over the wires rather fast, etc...
6-8 hours if you have everything jigged up and have all the tools is probably right. If this is your first time, 40 hours might be in line as well. I would ask to speak with some folks that the Toyota shop has made harnesses for and see if everything turned out ok. Speed kills some of the time. It is real easy to cross wires in the connectors that lead to redo's later; which can cause a fire or a ground issue, loss of an electrical component etc... That can take hours to trace which wire is crossed or just not crimped properly. And can become costly if you loose a component.
Whom ever you choose, do your research on that company before you spend the money.
Cheers and Good luck
