Time to sort out the blowby and poor compression issue on the old boy. Getting fed up with the mist when stopped in traffic.
I do plan on replacing the engine later on when I have time and funds to strip it down. Until then need to eek out the life of the current engine. Would it be wise to try and replace the liners myself? My maybe misguided plan is to pull the head, drop the sump and remove as little as possible to gain access underneath to pull the liners out of the top of the block. I have seen posts and YouTube videos a plenty that make it look so easy. As its a daily driver it's a weekend job so as little downtime as possible.
I had a mate at work machine a puller out of a tapped circular disc and use a threaded rod bridged over the block to pull them. Reverse action to refit them. Don't want to remove the engine so definitely bush mechanic style.
Am I disillusioned with this idea and about to open up a huge can of worms? Would love to know if anyone else has done this (successfully that is......) and best way to go about it without machine shop.
My minimal plan is new liners and rings STD size. Anymore cost and the replacement is brought forward.......
